power steering hose ** UPDATE 1/18 blew a line
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NEK5, Mar 16, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    alright i got the idle problem fixed....all set...the hose that went to the EGR valve was junk....but now i have another problem....when i was swapping in the new steering box one of the lines was real bad but didnt leak so we left it...well today when i was stepping in the engine compartment i must of step on that because when i turned the truck on to see if the idle was set...and i jumped out i saw fluid on the ground...looked in the engine bay and saw fluid coming out of that aluminum hose and i can feel a crack in it..... :mad: :mad:
    so how hard of a change is it??
    the horrible arrow shows where it cracked
  2. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    is the end of the aluminum hose flared??? would i be able to cut out the section then reflare it?
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Cheap and easy, buy a new one.
  4. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    its easy....thats what i want to hear.....where does it connect????
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    One end screws into the steering box, the other end screws into the back of the pump. I put one on our '94 Sub a few months ago in about 10 minutes and paid $20 for the new hose. :)
  6. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    paid $10 for hose....went from pump to cooler....pretty easy
  7. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Alright, last night i blew a power steering hose, and it happens to be the same one I already replaced..
    My question is, I`m almost positive its the pressure line, but i just want to make sure....
    it goes from the box to the cooler, or some hardline under the radiator?
  8. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    ttt
  9. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    You piad $10 that was a cheap hose.
    Buy the $20 hose it will last longer :D :haha:
    Seriously if you blew it that fast it was either a defect and I would return it or a bad quality and i would buy the best they have, maybe a goodyear.
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    If that hose goes under the radiator it is the pressure hose and it is going to the factory PS cooler.
    What he forgot to mention is that it is 15* outside and the truck was outside so i'm guessing the fluid frooze and when he started it the pressure burst the hose. That or a defective hose. I was PMing with him last night so i know more than most people who are only reading this post.
  11. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    so the pressure hose should have two screwed ends on it??
    when we replaced it last time, we hose clamped it onto the piece of hardline
  12. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    which is the biggest hose of the two??? I just went out and looked, and the bigger hose goes from the box to the PS pump? isnt that the pressure line???
    if it`s my return line, can i just re clamp in onto the hardline??? me and my buddy just inspected it, and nothing seems to be wrong with the hose??
    Also, when i popped the hood, the fluid was milky/foamy, so that would mean it was low and/or had water/condensation in it, right?
  13. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    well,its only the return side, so i`m going to check for damage, then cut and reclamp the line....
