power steering hose
Discussion in 'Parts & Trucks Wanted' started by big dan, Mar 4, 2007.
  1. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    I know I can get one at the parts store for like $10 but all I need is the metal part of the line and the fitting on the end. I cant find a fitting the same size with a flared piece of steel line around here any where but I know that a power steering line fitting will work and dont see the point in ruining a perfectly good hose for the fitting. so if anybody has on old hose that has a good fitting and metal line they would like to get rid of I could use one. needs to be one of the older ones with the flared fittings too. thanks
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    what style, flare or Oring fitting?
  3. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    I need the flared style. Ive already tried the o-ring style cause I have a couple of them layin around and it wouldnt work.
  4. skyyk5
    skyyk5 1/2 ton status
    Jan 2, 2007
    1,537
    N.E. PA
    I have one. Is it still needed?
  5. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    You better specify what size fitting you're needing. There are 2 different size P/S fittings. The pressure side is different than the return side.
  6. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    Thats what I was going to ask, also. But I have both. So if still needed, just let me know what one.
  7. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    whoops, sorry I need the pressure side. already tried using a fitting for the return and it was too small but the pressure would be just right.
    pm me a price and where to send the money too skyyk5, and Ill get it in the mail. thanks.
  8. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    I'll PM you as soon as I get it off.
