Power Steering Hose
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jburd, Jan 27, 2003.
  1. jburd
    jburd Registered Member
    Dec 19, 2002
    16
    Texas
    One of my power steering hoses has sprung a leak. The problem is I can't get it off to save my life ! There isn't any room to get a wrench in there and the nut won't loosen. Any suggestions ?
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I have a set of flare wrenches (is that what you call them?)
    They look like a cross between an open wrench and a box end wrench, with just enough of the box open to fit past the tube and hook onto the nut. They work great and are shorter than my regular Craftsman wrenches.
    HTH
    -- Mike
  3. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    take the pump off. then use a flare nut wrench on the fittings, that way you dont round them off, iff the line is trash its trash. a new hi pressure line is like $45 and the return hose is cheap
    Ryan
  4. jburd
    Dec 19, 2002
    16
    Texas
    Thanks for the help, guys.
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I have to pull my pump loose to get to my lines. /forums/images/graemlins/tongue.gif
