Power steering input seal...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89GMCSuburban, May 5, 2003.
  1. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    How the hell do you get it out?? I son't see how to get it out, unless there's too much junk on the box...
  2. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    I had to do this on mine, it wasnt fun. I took the box off my truck but in retrospect, i didnt need to. you will have to disconnect your steering shaft and get that out of the way. There is a doust cover that you will have to pry off the input shaft and below that is the seal. the way I got mine out was but jamming a pic and a screwdriver and gouging the snot out of it and working it out, then I drove the new one in. It was easier than I thought.
  3. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    Whatever you do dont pull the entire input housing out like i did. Its a bitch to get it back in right. The post above sounds like the best bet.
  4. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    I pulled the whole unit apart too, no fun
  5. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Woah, thanks guys, doesn't sound too bad...I'll just leave it on the truck, and if I screw it up, get it towed to the shop. Thanks!
