Power steering line
Discussion in 'The Garage' started by mudbog42, Aug 26, 2006.
  1. mudbog42
    mudbog42 1/2 ton status
    Jul 16, 2006
    452
    Florida for now
    Does anyone know of a good way to get that pressure line off on the power steering pump to replace the hose? There's like no room for any play with a wrench. I heard that there is a special tool used to get it loose??(86 K-5 , 350):doah:
  2. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    2 ways..
    It is a bear to get at!--but if you use the right wrench,its possible to do it without removing the pump..but its only held on by three or 4 bolts,and it comes off fairly easy..sometimes loosening all the pump to bracket bolts will allow the wrench to fit,without taking the pump right off..
    I usually cut the old hose right off at the fitting on the pump--then use a 6 point socket,or box wrench to remove it..just like I remove old brake lines..you can usually sneak the new hose fitting in ,and tighten it with a wrench enough so it wont loosen or leak without taking the pump off ,or loosening all the bolts..
    I made my 86 305's P/S pump fit the original pressure hose for a 250 six by using a 6" peice of 3/8" brake tubing bent to a 90 degree angle,and a 3/8" flare coupler/union --I was able to install the tube and pump as a unit,then easily thread the hose into the coupling..if only GM had designed it that way!..:doah: :crazy:
  3. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    You are supposed to use a line wrench for those fittings.
    If yoy don't have room, which you should, just pull it. Its easy...
