Power Steering - Need Mods? Or....?
Discussion in 'The Garage' started by 2Dogs, Feb 2, 2006.
  1. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    All,
    I have never had my PS work very well - after very light work in 4x4 it will go away entirely. Once in awhile it will even try to spool to one side or the other all on its own :eek1:
    Here is the setup I will have in a month or so: 37" MTRs on wheels with 3.5" BS (going from 4.25 to 3.5 BS will hurt the situation even more).
    Should I be able to run a pump and box combo that will power this setup or do I need to go to hydro assist?
    I have an AGR box at the moment, probably why I have had so much trouble. How do you think this box would react to the DIY pump mods?
    I already have a cooler installed, did not help.
    Sorry if this is the 5028th time you have seen this topic - please point me to relevant posts :wink1:
  2. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I am doing the pump mods for my new pump couse my steering SUCKS. I am getting hydro asst soon but just doing the pump now to see if it helps any. now if I could just get the damm pully off...:grind: :hack: :weld: :thinking: :pimp:
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    You should be able to pull the fitting out of the back of the pump without removing the pump from the vehicle (unless I am missing something different you are doing).
  4. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Anyone else have comments about PS mods for 37" tires??
