Power Steering No Worky
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by talldogg, Mar 4, 2002.
  1. talldogg
    talldogg 1/2 ton status
    Jul 26, 2000
    754
    San Diego, CA
    Well, I fired up my 454 for the second time this weekend after I finished the swap. The first time I only started it up and let it run for a little bit since I hadn't hooked up the exhaust up. Saturday I pulled it out of the garage and I let it run for a good while, BUT i noticed that my PS is not working.
    So I was just wondering if anyone has any ideas. Here's the setup, one used big block pump bought on ebay, original small block lines, plenty of PS fluid, I over-filled it actually. It appears the SB lines are longer and end up looking like two snakes going at it. So I wonder if the lines are restricting flow and not running the box. Or if simply need a new pump. Any thoughts?? Thanks!!
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    see if you got another pump laying around. if not try a new one
  3. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    I'd try the pump first. But also make sure that you don't have too much air in the lines
  4. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    I think if you leave the cap off and work it side to side while running it bleeds the air out. Anyone correct me if I'm wrong.
  5. talldogg
    Jul 26, 2000
    754
    San Diego, CA
    Thanks for the help guys. I didn't think about there being air in the lines, but it definitely be a possibility in this case as the lines were off the pump and box for a while. I might try getting new lines and making sure there's no air in them and then if that doesn't work, I'll bit the bullet and get a new pump. Thanks again.
