Power steering problem!
Discussion in 'The Garage' started by 88K5DT, Aug 8, 2005.
  1. 88K5DT
    88K5DT Registered Member
    Aug 7, 2005
    13
    California
    I recently replaced my power steering pump and bled the system. The pump winds and makes a high pitched hum when driving, so I bled the pump again- With pump cap fastened I lifted the front end with engine off and turned the wheel back and forth about 30 times then I put cardboard under tires and sat it on the ground and turned the engine on and turned the wheel back and forth about 50 times.Afterwards I look at the pump and Power steering fluid has leeked out onto the ground and fluid inside the resevoir looks frothy. I believe the fluid is leaking from the cap but it is hard to tell(you can barely see the pump under th AC compressor and brackets). So then I take the car for a drive and it still hums and when I turn the wheel all the way and it makes a loud pop sound. It does not sound good.
    Does anyone know what might be the problem?
  2. Bouche89K5
    Bouche89K5 Newbie
    Aug 8, 2005
    3
    Memphis, TN
    You might have to much fluid in it. Did you get any air when you bled the system? Try bledding the system with someone turning that wheel at the same time. Hope this helps.
    Bouche
  3. 88K5DT
    Aug 7, 2005
    13
    California
    I am new to bleeding a power steering pump so I am not certain as to what look or listen for when bleeding it? It is filled at ok level.
    Is it really that bad to overfill pump?
  4. 88K5DT
    Aug 7, 2005
    13
    California
    Power steering
    Is it normal if my power steering is not bled properly to make a single loud pop sound when I turn the wheel all the way while driving? It also hums but I hear that is from not bleeding properly. I am having trouble trying silence my pump after recent installation.
    Does anyone know what to look or listen for when bleeding the system?
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    frothy stuff in fluid would either be water or air
    one or other
    im not sure what you can do, other than make sure you dont have lines backwards, hi/lo
    dunno,
