power steering problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Jun 22, 2003.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Ok, ive been having problems with my PS and Im not sure what it might be, i replaced the pump but its still hard to turn when im not revving the engine. If i give it gas around corners it will work better. Any thoughts on this? Could me gearbox be jammed up or something? I would hate to have to remove that heavy SOB again.
  2. 77k5bogger
    77k5bogger Registered Member
    Feb 3, 2003
    40
    Winneconne Wisconsin
    I kinda have that same problem, my guess is that the stock power steering cant handle turning larger tires at lower speeds. Im gonna be upgrading my pump and adding hydrolic assist soon. /forums/images/graemlins/k5.gif
  3. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    When you replaced your pump, did you check and see if the pulley was turning freely? Did you mean that you also replaced the steering gear? Reason I'm asking is because You don't have to remove the steering gear to change the pump. Did you also cycle the pump to bleed the system of air?
