Power Steering Problems
Discussion in 'The Garage' started by cbbr, Apr 4, 2005.
  1. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Looks like its leaking from the top of the gearbox where the shaft goes in. Leaking pretty good when the pump is pumping.
    LMC only shows a full Gearbox. Can anyone tell me if this is an easy fix.
  2. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    Isn't there a seal there?
  3. cbbr
    Jul 17, 2004
    14,681
    Hoses are new and tight. The leak is right where the shaft goes into the gearbox.
  4. beastofablaze
    Apr 4, 2005
    441
    CA
    yeah i realized that didn't make sense(notice the edit)... at first i thought you meant on the top where the hose screws in but im pretty sure there is a seal where the shaft goes in... LIttle help?
  5. cbbr
    Jul 17, 2004
    14,681
    Anyone know if the seal (must be one) is easy to service?
  6. dyeager535
    26,980
    Mine appeared to be leaking from the same general place (pretty hard to see clearly) so I had some of that stop leak powersteering fluid around, and added that. Problem seems to have cleared up.
  7. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Look here, should be what you are looking for :)
    Input seal
  8. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Here try this.
  9. cbbr
    Jul 17, 2004
    14,681
    Thanks guys.
