Power steering Pulley removal?
Discussion in 'The Garage' started by MaxCrack, Oct 22, 2002.
  1. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    /forums/images/graemlins/1zhelp.gifWell, I thought I was just supposed to used a pulley puller. So I did, one of those three jaw thingies with the big bolt through the middle. Well, not only did the pulley puller not pull the pulley, it bent the [censored] out of the pulley before I realized the pulley puller was not pulley pulling properly. Now I need to go to Pick and Pull and prospect me another pulley to pull, with a pulley puller perhaps. But I need to know the proper procedure for pulley pulling so I can pull the pulley properly without damaging the pulley.
    Oh yeah, and how do I put it back on?
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Go to a "good" parts house and they will do it for you. I bought a new pump,and they pressed on the old pulley on the new pump for free. /forums/images/graemlins/rotfl.gif
  3. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    You need a puller like this one.pic You can borrow one from Autozone with a $15 or $20 deposit.
    There is a little groove in the pulley near the shaft. Use the second part in the pic to pull it off. Remove the metal sleeve and put the two halves around the puller and the pulley. Then put the sleeve around them so they cant come off. I think you can probably figure it out from here.
    To put it back on use the part on the left(might have to use the other bolt). Screw the long bolt into the pump shaft, be sure to catch plenty of threads. Then tighten the other part down until the pulley is flush with the shaft.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Ya just need the right tool. A power steering pulley remover. /forums/images/graemlins/wink.gif
  5. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    "But I need to know the proper procedure for pulley pulling so I can pull the pulley properly without damaging the pulley.
    Perhaps you could peruse the pages of a Chilton's publication for the proper pulley pulling procedure. Possibly procured from a parts purveyor.
    ________________________________
  6. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    If you rent a puller from Autozone the puller usually has directions with it
  7. khotmer
    khotmer 1/2 ton status
    Oct 23, 2002
    228
    columbus, oh
    to bad your way out west i have a pump and pully id sell ya for 15....
  8. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    cant you buy the pump with the pulley installed?maybe a couple bucks more.i never replaced one but i had a friend that did and he ruined his pulley in the same way.we just happened to be in the army and had a pulley off a hummvee one that fit his pump.by the way your first post is like a tongue twister.so many pulleys and pullers i had to read it twice to get it strait.haha
  9. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I think the topic has been covered by now, but I just had to commend you on your "imaginative" post!!!!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    Not too often that I laugh reading about PSP pulleys.... /forums/images/graemlins/grin.gif
