power steering pulley?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by OKIEnVA, Jun 16, 2006.
  1. OKIEnVA
    OKIEnVA Registered Member
    Jan 16, 2006
    32
    Northern virginia
    i got a 91 blazer with a serpentine belt. and heard a horrible raquet today and a bolt at the bottom came out and was rubbing the inside of the pulley. i got it threaded a lil bit enough to stop the noise, but how do i get the pulley off so i can get in to it and tighten the bolt?
  2. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    pressed on and need puller and then when done need installer. auto zone has the complet loan a tool kit.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Be warned though, I've taken a few on and off but once it just DID NOT want to come off and I had to cut and grind it off of the shaft. That was a BAD day!
  4. OKIEnVA
    Jan 16, 2006
    32
    Northern virginia
    well thank you guys. ill give er a try.
  5. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    make sure you use an installer, you'll wreck the bearing if you just whack it on...
