Power steering pump bracket is crooked, help me Mr. Wizard...
Discussion in 'The Garage' started by Desert Rat, Aug 30, 2004.
  1. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Ok, I go to put my new PSC power steering pump in and use the old "pivot adjustor" bracket. I had removed my A/C pump and accompanying garbage since I figured I wouldn't be using it anyway. I get it bolted in and low and behold the pulley on the pump doesn't really line up with the main pulley. It is slightly farther out and at a slight angle. I've fiddled with it a bazillion times then finally wacked on it six ways to Sunday to get it configured right. I can get it close, but not quite there. Anybody know where I can pick up a new or used one besides Pick n' Pull? I tried LMC, don't sell one. I tried Classic Industries, discontinued. I tried the dealership, discontinued. Got a e-mail into PSC but nothing back yet. Anybody else run into this and need one too? Or, is there an easier solution than replacing the bracket?
  2. stretch67
    stretch67 1/2 ton status
    Nov 1, 2003
    171
    bozeman mt
    i may have one is it smallblock or bigblock? some of the brackets use spacers between the block and bracket do you have those in place?
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    DR, you working days or nights now? I got 1 or 2 extras in the garage for a SBC and all my Chevies are BBC now. So come pick one out. /forums/images/graemlins/thumb.gif
  4. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Yeah, I fiddled with spacers ala different amounts of washers. I think the bracket is bent so much I don't think I can get it in line even with angling it with spacing.
  5. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Working days now. I'll respond in e-mail.
  6. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    i think the AC bracket shares a bolt with the PS bracket in some cases. it may be causing your problem.
