power steering pump differences 75 - 88?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 75K5, Sep 19, 2002.
  1. 75K5
    75K5 1/2 ton status
    Mar 14, 2001
    268
    Michigan
    I have a 75K5 that I have been playing with for a little while. The only thing I don't like is the play in the steering wheel.
    Recently I bought a steering box off a 90K5 on ebay. It looks the same but has different hose fittings going to the pump. I was going to just get adaptors, but I can now get an 88-91 power steerin pumps for under $40. Will the newer pump fit on the older brackets?
    Thanks,
    Brian
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    If it does not, you can just change the fitting on the back of the pump where the high pressure goes. Should look like a big bolt. It unscrews and then you can just swap them.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    79 and older use std thjreads and flared compression fitting, and 80-up use metric crap with O-ring style fittings, you can swap the threaded in fitting on back of pump yes, whther pumps change din 88 i have no idea
    good luck
