Power steering pump filter?
Discussion in 'The Garage' started by stallion85, Mar 12, 2004.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I am having prolems with my steering since a recent power steering pump and input shaft kit on the steering box. The pump was out of a junk yard but was rebuilt not the original. Now my problem is the steering is off some how. When I make a sharp turn and try to straighten the wheel out I have to actually turn it back straight. It should automatically want to go back straight if I am correct. I was told it could be the filter in the pump is clogged and the gear box isn't getting enough pressure? It turns fine with no noise or extra effort /forums/images/graemlins/deal.gif I am stumped. My only other option is to replace the gear box! /forums/images/graemlins/1zhelp.gif
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    do you have any front axle shims? your caster/camber may be off, making your tires not 'return to center'
    also check your steering stabilizers, they may be bent.
  3. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
    Stabilizer seems fine, Not sure how to check the shims????
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Did you adjust the preload on the Box? You might have it too tight /forums/images/graemlins/dunno.gif
  5. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    That might be it, i am putting another gearbox on next month, That should fix the leak I can't get rid of and hopefully my steering problem /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif
