Power Steering pump Flare to O-Ring converter?
Discussion in 'The Garage' started by Russell, Apr 12, 2006.
  1. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,922
    333
    Fort McMurray, Alberta
    Hey!
    Does anyone know if anyone sells a fitting to convert a flare power steering box to a o-ring power steering box?
    If so, where would a guy go about buying one?
    I just need one for the pressure side of my power steering box (switching to hydroboost, hydroboost uses an o-ring, gear box is a flare)
    Thanks!
    Russ
  2. dyeager535
    26,978
    Is the fitting itself removable?
    Sorry if I'm re-hashing what you already know, but on the regular power steering gear boxes, the fitting on the back of the box is interchangeable between the o-ring and flare fittings, so you just remove the old one, put it on the new, and you can run your old lines.
    I apologize if this doesn't apply to hydroboost. :)
  3. blazindorito
    blazindorito 1/2 ton status
    Nov 25, 2003
    2,047
    Southern California
    I had to do the same thing. I had to convert from O-ring to flare fitting. The flare fitting did not fit in the power steering pump side. To fix this I went to the junk yard and pulled a flare fitting line and had it adapted to the o-ring line. I went to the junk yard and pulled 2 of them off so I can have one as a spare. To make the new hose was pretty pricey it cost $25 to make each hose, and I supplied the fittings.
  4. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    its simple
    jut swap the fittin in the back of the pump for whichever of the two you want, the style of hose end you have 79 older
    or 80 and up
    real easy
    good luck
  5. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Just did this a few weeks ago. Unbolted the fitting off the back of a mid80's box and swapped it into 78 4x4 ps box.
    So what the others said X eleventy billion
  6. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    yep, thats is how you do it
    good luck
  7. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    There is an adapter fitting available. I don't know from where. But, someone put up a link in a past post, do a search. But, like everyone else was saying, it's probably easier, faster, and cheaper to change out the fitting in the back of the pump.
  8. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    yeh unless you didnt have the right hi side hose
    good luck
  9. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Guys, he is asking about a conversion fitting for the steering gear box and not the power steering pump. I know there is a fitting to go from O-ring style to flare style but i'm not aware of any fitting to go from O-ring to flare.
  10. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I bought a kit, IIRC for about $5 that converted o-ring style to flare style. It worked flawless for me. All they are, are small aluminum pieces that install into the connection to convert it. I bought them from a place in California, but I can't remeber the name. I found them when researching for my hydroboost conversion, and they were recommended from a IH website. I'll see if I can find that again and post up.
  11. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Here you go:
    They are bushings made by Lee manufacturing.
    818-768-0371
    Pressure 40620 $3.97
    Return 40630 $3.97
    They tap right in using a 1/4" bolt and nut as a driver!
    http://www.leepowersteering.com/
    They were very polite, and shipped fast when I bought the adapters. Looks like their website has much less on it than it once did. I guess they may not be producing those adapters anymore. Give em a call.
    Looks like I made 1000 posts with this one.
  12. Russell
    Jun 23, 2000
    7,922
    333
    Those would work sweet, but they work the other way of what I'm needing :)
    I need to go from a 45 degree flare fitting to a o-ring type fitting.
    I emailed lee manufacturing to see if they have anything anyways, but I think I may have found a fitting that would work made by aeroquip. I'll need to go over there and take a look and see.
  13. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    You could use a hose with flare on both ends, then use their adapter on the side that has an o-ring attachment.
  14. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    Anyone ever identify a fitting to do this? I have a brand new rebuilt 2wd box from a 77 truck I'd like to put in my 85 without swapping pumps/hoses (its also hydroboost)
  15. Russell
    Jun 23, 2000
    7,922
    333
    Nope, I gave up and put the vaccum booster back on...
    I may be about to swap over though, A buddy of mine has provided me with a nice steering box so I can swap the top ends around, and wind up with the proper fitting...
  16. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Convert the hoses to JIC with "Re-useable" hose ends, and use a whatever to JIC adapter wherever the hoses connect to the box, pump, or HB unit.
    The re-useables are common hydraulics fittings, and so is the hose. Both are rated for more pressure than a typical PS pump delivers and the hoses are then feild repairable. They are also one of the two types of hose ends commonly used on ram assist installs.
