Power steering pump hitting the crapper?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Sep 19, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Well today my power steering started acting up...It always used to squeal when I went to the either left or right lock but now it is squeeling a lot more...It is fine when I am moving but when I am stopped, I can only turn the wheel 3/4 to 7/8 of a turn before the pump belt starts squealing...When the pump squeals, I notice a slight drop in RPM and the steering, as one would expect, gets very hard unless I roll a little...The fluid is a little low but it was still doing it when topped off...So is it the pump going south or the box or what?
    Thanks gang...
    Chris
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Sounds like it's just a loose belt. If it's been squealing for that long then the belt is likely glazed and you'll need a new one, but more than likely that's the problem. </font color>
  3. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    I would have someone watch the belt to see if it is slipping if that's not it then it's your pum starting to lock up.
