Power Steering pump not lining up... Help...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Dec 2, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    OK.. got the newer motor in and for the life of me it seems the powersteering pulley and the crank pulley's wont line up...
    I can get a belt on there but it's at a angle.. I'm afraid it will get fried from rubbing.. it isnt a terrible angle but it def. isnt aligned Like i'd like it... The pulley on the crank and the pulley on the waterpump do line up... so it is the ps pulley...
    Is there an adjuster for these?
    /forums/images/graemlins/1zhelp.gif
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    im having the same problem on the wifes 76...
    ok, well i am to lazy to swap the AC setup brackets off one of the pumps on my shelf and the pullys off my pump to her pump...
    anyway, you have the wrong pullys and mounting brackets. the motor you put in may have had air. if you didnt swap EVERY pully off your old setup onto your new setup then i am almost positive that this is the problem. try using ALL your old stuff, or ALL the new stuff. if you mix and match them then ya run into problems. as i have found out anyway.
    maybe this is not your soloution, but it is mine, as soon as i get my a$$ in gear and do it anyway.
    Grant
  3. reddog64
    Nov 9, 2000
    3,325
    I used the only set of stuff I had... sounds like i need to find a different pump setup...
    /forums/images/graemlins/confused.gif
  4. Geno
    Geno Registered Member
    Nov 18, 2002
    52
    Dorchester, Nebraska.
    /forums/images/graemlins/cool.gifCheck your water pump there are two different types for different power steering mounts, one has a threaded hole for mount and one has hole all the way through with nut on the back , check out your old one to see if the new one is different. /forums/images/graemlins/thumb.gif
  5. reddog64
    Nov 9, 2000
    3,325
    I looked at it the other night... I bolted teh PS pump to the threaded hole... I bet I could put a washer behind it and the other bolt holding it, the adjuster, and it would line up, or at least better...
    ???? /forums/images/graemlins/confused.gif
  6. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    I bet you that the ps pump is in the bracket wrong ... I did the same thing when I got it in the bracket I saw that the pump pulley was at an angle and there was no way I was going to let that go so I pulled it out and scratched my head snd moved the pump (not sure which way I did move it in the bracket but I want to say I moved it foward and then it lined up...)
    The bracket also has a bend in it to make the pulley straight with the crank so when it is in the right way it will line up...I hope it helps....Mike
