Power Steering Pump Pulley Alignment?
Discussion in 'The Garage' started by jaros44, Jun 11, 2006.
  1. jaros44
    jaros44 1/2 ton status
    Jul 12, 2005
    408
    Outside Phila. Pa.
    Just put the front of my motor back together and the PS pulley is cocked by 1/2", I used all the stock parts and brackets, wat up? Jim
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I bet that you used the wrong bolt on the uper/pas side of the PS bracket.
    Is the pass side of the PS pump pulley too close the the intake?
    Is a standard bolt holding the above mentioned part of the bracket?
    It should be a piece of allthread w/ a built in nut about 2/3 the way down.
    Install the allthread to the head
    Install PS pump bracket to allthread
    Put a nut on the allthread bolt to hold the bracket in place.
  3. jaros44
    Jul 12, 2005
    408
    Outside Phila. Pa.
    No actually I'm an idiot!!! there is a 3/8" spacer that I put in the wrong location. I put it on the stud on the back of the pump, 2 yrs. ago, so I wouldn't lose it. Only took a day to figure out the proper location of the spacer.
  4. readymix
    May 30, 2004
    6,706
    26
    At least you figured it out
  5. jaros44
    Jul 12, 2005
    408
    Outside Phila. Pa.
    Thanks for your time and input. Jim
