Power steering Pump Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Redfrog, Feb 18, 2002.
  1. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    Will the power steering pump of a 82 2 wheel drive work on a 79 4 wheel drive? the look the same, so how about it will
    they??
    *wink*
    my 79 rust bucket will run over your 2001 chevy 4X4 tahoe plastic wagon
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    If the pulley/shaft is the same it should bolt up. Just check all mounting places.
    My .02,
    John
    <font color=blue>"When all else fails, read the instructions, or get a bigger hammer"</font color=blue>
  3. Big_B_Murphy
    Big_B_Murphy 1/2 ton status
    Dec 28, 2001
    159
    New Stanton, PA
    Those pumps are the same. The brackets and pulley may be different, but the actual pump is the same.
    <font color=red> It is just as much fun to build it as it is to bash it</font color=red>
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    The only thing that changed over the years was the fittings on the inlet and outlet and the valve. The valve can easily be swapped into the new pump from the old just by unscrewing the pressure outlet fitting. Of course, the pulleys and brackets may also need to be swapped. That same basic pump design is still being used today (with a few refinements).
    <font color=green>Top signs you don't have a real 4x4:
    4) Twin Traction Beam
    3) Made by D.C.
    2) 5 lug nuts
    1) Unibody</font color=green>
