Power steering pump shaft play
Discussion in 'The Garage' started by mechted, Oct 29, 2005.
  1. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    well @&(%
    i got a power steering pump with my hydroboost set up, and the thing has about a 1/32" of forward to rear play in the shaft of the pump... seals all look fine, and no off axis play in the shaft... but i need a new one right?
  2. diesel4me
    Jul 24, 2003
    17,540
    926
    Massachussetts
    fairly normal...
    SOME end play is normal--unless its noisy,leaking,or has radial play in the bearings,I'd say its normal..all my P/S pumps will move in and out if you push and pull on the shaft at least enough to be noticeable..I wouldn't worry about it... :crazy:
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Average shaft end play is about 1/16". Yours is fine.
  4. mechted
    Oct 19, 2003
    765
    Granbury, TX
    yay
    thanks guys
