Power steering pump shot
Discussion in 'The Garage' started by 84CUCV, Jul 30, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    starting to squeal and the fluid in yellow. So it must be shot right?
    thanks m ike
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: Power steering pump shot *DELETED*
    Post deleted by HarryH3
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    That would be great! thanks
  4. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    If you think the fluid is contaminated, you can drain the pump and what you can from the box. Then refill and put front end on jack stands with tires lifted off the ground. Cycle the steering full left then full right about 10 times to bleed the system. This may take more turns. Check the fluid to make sure there is no bubbles foaming at the top. If so let it sit for a while and repeat the process.
