Power Steering Pump Specs?
Discussion in 'The Garage' started by OffRoader93, Feb 7, 2005.
  1. OffRoader93
    OffRoader93 1/2 ton status
    Nov 30, 2002
    262
    How many GPM and PSI does a stock power steering pump push? Thanks.
    Brenton
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    minimum GPM is 1.32, max GPM output is 3.1 - 3.5
    initial pressure should be in the 80 to 125 range at idle.. theirs a whole series of pressure tests that can be done... the flow control valve and relief valve seem to be the big issues with the pumps...
    there are some special tools that aid in testing...
