Power steering pump...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Feb 3, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Mine's leaking like a b!t#h...
    How hard to replace...???
    Please see my other post...
  2. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    they're not all that hard to replace but it does take some time,,it's not the easiest thing to take off. especially if you still have the a/c pump hooked up.
    <font color=purple>ANYBODY LOSE THEIR JEEP????????[​IMG]
    I JUST FOUND ONE UNDER MY BLAZER!!!![​IMG]
    [​IMG][​IMG]</font color=green>
  3. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    I just did mine a few months ago. It is easy. In and out in 3 hours (I have air tools, so it will take longer without). I wanted to make sure I got rid of most of the leaks, so I got a new high pressure line and a new return line. you should get all of the fluid out of the steering box as possible before you put it all back together and fill up with fluid. It takes a lot of fluid, I forgot how much exactly, but a lot. The biggest problem I ran into was I didn't have a pully puller to switch the pully to the new pump. It took me about an hour to drill out the old pump shaft and remove the dang thing. If you are going to tackle the project, make sure you get a puller specialy desiged to grab the little lip on the pully.
    Insurred by Smith & Wesson
  4. Big_B_Murphy
    Big_B_Murphy 1/2 ton status
    Dec 28, 2001
    159
    New Stanton, PA
    If you are going to replace just the pump definatly buy the puller to remove the pulley from the shaft. It is easier and probably cheaper to buy the assembly from a junkyard and not have to worry about swapping pulleys.
    <font color=red> It is just as much fun to build it as it is to bash it</font color=red>
  5. Those pumps/reseviours are about $45-50 with the core. I did the job in about a day, but I replaced the water pump, and fuel pump as well as all belts and hoses.
    Mine started leaking as well, it was leaking from the "phantom-who-know why it's there" plug in the back that also connests to the tighting bracked...it just worked it's way loose, got in there and tightened it up and no more leak.
    As for the pully tool, just borrow one from the parts store, it's free but they put a deposit charge on you card, or you have to leave cash or check. Then when you return it they give you the money back.
    '84 K5
    Chevy in my blood.
  6. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Clicky: <a target="_blank" href=http://westtexasoffroad.homestead.com/powersteering.html>http://westtexasoffroad.homestead.com/powersteering.html</a>
  8. TheLakeRat
    Nov 29, 2001
    363
    Thanks Harry. I'm one hell of a RedNeck. but I'm a computer moron. ;)'
  9. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Now Hold On! When I had my motor rebuilt they had one of the hose outlets from the back of the pump right up against the exhaust. I put a screw driver in there to pry it back just a little and tore the damn reservoire. I went and bought a new pump from Napa- $70 I think. Tried getting their machine shop to swap pullies for me and dude told me they don't do those anymore. Why? Because the fricken puller, even the top of the line models like Matco and Snap On, have ruined brand new pumps by breaking of inside the pully shaft, You can't fix it he said so you start all over with a new pump-more money. I called many people around here (Memphis) and got simular answers. I ended up just cleaning the holy crap out of the torn area and used JB Weld to fix it. So far so good. The dealer said they'ld do it for like $35 and no guarantees. I did find a shop later that said they do them all the time for $15. I just thought I'd let you know what my experiance has been.
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s6superliftand33s.msnw?albumlist=2>http://communities.msn.com/OffroadK5s6superliftand33s.msnw?albumlist=2</a>
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt
  10. Big_B_Murphy
    Dec 28, 2001
    159
    New Stanton, PA
    I know what you mean. I tried swapping the pulley from my broken shaft to the new pump. I was in a bind because this happened to me on christmas eve. All junkyards and Dealeships were closed. Found a pump at a carquest that was open. They wanted about $95 for it. Bought the puller, It was only about 20 bucks-you can never have enough tools anyway. Swapped the pulley off the old shaft to the new shaft no problem. Or so I thought. by the next day the pulley had wallowed out and worked itself free to the point where you could slide it on and off with ease. The day after christmas I found a junkyard that had the whole assembly for $75 and have not had a problem since.
