Power steering return line i.d.??
Discussion in 'The Garage' started by shane74, Mar 17, 2004.
  1. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I replaced my power steering pump last night, and I knew I should have bought a new return line hose, but I couldn't take it off because it's my DD and we are down to 1 rig till the wife's car gets out of the shop. ANYWAY...does anybody know what the I.D. of that return line hose is? It's leaking pretty bad and I really need to fix it today.
    Oh, yeah, it's for my '74.
    Thanks!! /forums/images/graemlins/waytogo.gif
  2. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    5/16", be sure to get the correct hose as fuel hose will deteriorate(sp?) with oil in it.
  3. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Thanks! Yep, I'll be using hose for hydraulic fluid. We have a ton of it at work, so I can snag a piece before I go home tonight. /forums/images/graemlins/woot.gif
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    3/8 is hose size
  5. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    3/8 pressure side, 5/16 return side.Be sure and get oil and temperature rated hose, Goodyear make's good quality hose for this kinda stuff. /forums/images/graemlins/grin.gif
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I just did both pressure and return in -6 line and adapted JIC fittings
    slipped right on the return res nipple temporarily hose clamped
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I used 3/8" and it went on fine.
    I got some that had a outter braid for reinforcement from NAPA. Most other auto parts stores tried to sell me fuel line /forums/images/graemlins/rolleyes.gif
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    fuel line would work
    there is no pressure on the return
    I wouldnt do it
    I am looking at welding a -6 JIC to the res
    the 5000psi line is way overkill but I like the look
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    -6 = 3/8"
    They do make special hose for return lines if you want, but fuel line should work fine.
    I can't see how one petroleum product differs from the other, if it's rated for fuel, should work fine for p/s fluid. If there's any question get trans line hose, which is what I usually sell anyway.
  10. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I thought the reason to not use fuel line was temp related /forums/images/graemlins/confused.gif
    At any rate the overbraid will help it to last longer and not wear through.
