Power Steering Suddenly quit!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beefcake83, Mar 19, 2001.
  1. beefcake83
    beefcake83 1/2 ton status
    Jun 24, 2000
    240
    Alaska
    Hi all - has anyone ever seen/heard of a K5's power steering pump suddenly just quit without warning. Mine seems to have done this, and want to make sure it's shot before paying for a new one. It worked the other day when I went for a drive. I parked and came back 10 minutes later, and went to drive off, and no power steering. I always thought that they would whine more, and gradually go bad. I checked and there's plenty of fluid and the belt is still intact. Wierd. Thanks, Gary
    Gary Graham
    '83 GMC Jimmy 350 'Beefcake'
    Eielson AFB, Alaska
    Metallica & Mountain Dew
    http://community.webshots.com/user/beefcake83
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Mine did that...It could also be the steering box. The way to check is to turn on the truck and then take the cap off the resorvoir and see if the fluid id moving around, I *think* you should see the pump turning.
    90K5
  3. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    dido on that. thats the procedure in my chiltons manual
    Insurred by Smith & Wesson
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    485
    Grand Rapids area
    The pump is pretty easy to replace. You get a Limited Lifetime from Autozone on a rebuild for about $30. I don't know if this will work or not, but you may be able to tell whether it is the pump or the gear by detaching the pressure hose, disconnect the ignition and tap the starter over to see if fluid flows. They work in part by centripetal force, so they need a certain rpm to flow any oil. If that flows, then you should be able to detach only the return hose and check for flow out of the gear. However, you will probably need the valve open, so one person should sit and pull on the steering wheel while the other watches for oil coming out.
    The more straightforward way is to replace the pump and if that doesn't fix it, then replace the gear, but the gear is usually expensive and you don't always know if a junkyard one is good or not.
    <font color=green>Stupid tourist at Mammoth Cave, Kentucky: "How many miles of unexplored passages are there?"</font color=green>
