power steering works intermittently
Discussion in 'The Garage' started by colbystephens, Sep 9, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    why is it that i can't seem to get my p/s pump primed all the way? i had it out of the engine about 3500 miles ago, and it still screeches really bad when i'm not moving and am trying to turn the wheels. man, it pisses me off. makes a racket and makes parallel parking not so much fun. any thoughts?
  2. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    My first thoughts are
    loose belt
    low fluid
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Hey Colby. PS pumps are self priming/purging. I'd pull the belt off and check the pulley for play. If you have any play in it, the bearings in the pump are shot and it needs to be replaced. If not and it still screeches, I'd look at fluid level, belt tension, and maybe even replace the belt.
  4. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    ya dude that seams to usually be the case with sqeeling belts, loose or glazed or both.
  5. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    My vote is for a bad pump.
  6. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i don't think it's the belt - its nearly brand new (3k miles) and is tight... i don't want to deal w/ replacing the pump. that's a bummer.
  7. diesel4me
    Jul 24, 2003
    17,540
    926
    Massachussetts
    check this first..
    Your pump might have a sticky pressure regulator valve,or some crud blocking it once in a while..its biult into the "bung" the pressure hose screws into..
    Are the hoses new??..old ones sometimes get mooshy inside,and can act like a check valve or collapse and block the flow of fluid..I'm also thinking if the hydro-boost has problems,it might be restricting the flow of fluid..usually when a pump goes bad,it doesn't put out enough pressure ALL the time,and is most always accompanied by a loud whine or growl..a pressue gauge might aid in diagnosis..could be the steering BOX binding up too!.:crazy:
  8. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    power steering pump 42.99 at thrifty auto supply
  9. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    u gonna hook me up if you still work there? :)
  10. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I changed two ps pumps on my rig after I did hydro steer. Before the swap it whinned and squeal also. Turned out the belt was loose. Although it didn't feel loose.
  11. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    for what it's worth, it was the pump. i replaced it tonite and it's nice and smooth! man, i haven't had good powersteering in almost 6 months. incredible concept - that powersteering!
  12. chopped&bobbed77burb
    chopped&bobbed77burb 1/2 ton status
    Oct 5, 2005
    925
    milwaukie,oregon
    Now you just gotta get the rear axle locked up on that Blazer so you can actully wheel it and not have to be yanked with a strap behind a camo burb over all the little rocks & obsticals :haha: . Speaking of which :wink1: did you ever get some tow hooks installed on your frame ? YOU need them !
  13. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    nope. no tow hooks yet. btw, i ran that trail again and was able to make it thru on my own power - tho it wasn't wet at all... speaking of you and wheeling - do you ever? :haha: are you going w/ me on the 11th? i've got another method that works ok for towing if i need it... you're right tho - i really want a detroit for that 14bff. :)
  14. chopped&bobbed77burb
    Oct 5, 2005
    925
    milwaukie,oregon
    Money's a bit tight right now and I can't really afford to fill that 31 gallon fuel tank in the burb to just go play in the wood's . I've got to change the front spring bushing out so I can run larger bolts ( at the shackle ) . I seem to snap those 7/16 shackle bolts almost every time out :mad: . I always carry spares but it's getting really old :rolleyes: . At least I have a rebuilt front drive shaft now . I wonder how long that will last . I ran that same trail with the little sammy and it's got car tires on it and it's open front and rear :haha: . It was dry . We need to do Browns camp . I don't know what trail's are still open . Where are you off to this time ? I got some boulders delivered to my drive way so I have sort of been wheeling :haha: .
