power steering
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dmoney, Jan 25, 2007.
  1. dmoney
    dmoney 1/2 ton status
    Jan 21, 2007
    119
    Silverhill, Al.
    my power steering is leaking, i have replaced the hoses so I think I need a new pump, should I go with an upgrade or stick with stock, and if an upgrade witch one? I have 33s now but i want to go to 38s.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    38's are going to put some strain on your steering, I would go with a good lifetime warranty stock replacement, they will be more forgiving and more ignorant when you will be replacing it.
    If you were considering serious OFF roading I would suggest crossover, but it's probably too much work for just a DD, which I realize is what you have.
    :D
  3. dmoney
    Jan 21, 2007
    119
    Silverhill, Al.
    yes it is a dd that will very rarelly see offroad time, so I think stock will be ok, do you think I need the brace I have heard about on this forum?
  4. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    absolutly,:D
  5. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I would check the frame, if it's not cracked yet, I would put the bolt on brace or any kind of reinforcement, if it's cracked repair the crack and then put a brace.
    I had a 73 that never saw any off road and the frame was cracked.
    And it had 31" tires.
  6. dmoney
    Jan 21, 2007
    119
    Silverhill, Al.
    where does it crack?
  7. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    It crack between the bolts where the steering box bolts to the frame.
    Mine fell off the frame, the square piece in between the 4 holes completely broke off and fell.
    :o
  8. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Where is the leak?
  9. dmoney
    Jan 21, 2007
    119
    Silverhill, Al.
    cant see the leak. is it is around the pump, but cant see where from...
  10. cbbr
    Jul 17, 2004
    14,681
    It might just need a seal which is a lot cheaper than whole new box. Look at it carefully and see i you can figure out where its coming from.
  11. dmoney
    Jan 21, 2007
    119
    Silverhill, Al.
    where is the seal?front or back?
  12. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Back.
    The box is like a bowl with a machined piece that fits in it from the back. :D
  13. cbbr
    Jul 17, 2004
    14,681
    Look here and you can see how I learned all about it with pics. And here for a diagram of the box.
  14. dmoney
    Jan 21, 2007
    119
    Silverhill, Al.
    you guys are the s*%t cbbr and iceman , Thanks
