power steering
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ArmyEd, Sep 1, 2001.
  1. ArmyEd
    ArmyEd Registered Member
    Jul 1, 2001
    Fort Campbell, KY
    I have a 79 K5, the power steering is not working, what power steering pumps are compatible and what parts would i need to get some power assist to turn these damn tires, i don't wanna spend $600 for new stuff, i just want to get it from a local junkyard
  2. tRustyK5
    Jul 23, 2000
    E-town baby!
    I took my old pump with me when I went scavenging. There are two different types of line fittings that were used and I'm not sure which years got what. One is a flare fitting style and the other is an 'O' ring boss fitting style.
    Then there are the differences in pulley location. My old pump had dual pulleys on it and the new one has a single on it...but it works because I no longer have AC.
  3. dyeager535
    Just about any of the power steering pumps will fit *if*you get the right hoses. FWIW, you can pull the valve/fitting out the back of the pump, so that you can switch between "metric" and "standard" hoses, depending on which steering box you have.
    My pressure line sticks straight up out of the box, but then loops down under the pulley, to fit perfectly. Looks kind of odd, and isn't "stock" but it works fine. Easier just to get the right pieces though, IF you can find them.
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
