power steering
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by pilgrim, Nov 7, 2001.
  1. pilgrim
    pilgrim 1/2 ton status
    Sep 10, 2001
    247
    new hampshire
    so i installed agr's power steering pump and box. and i thought that it would be super easy turn and all but i'm having some trouble. when i'm moving down the road it seems to work ok , but when i'm stopped on tar and i go to turn the wheel and it's darn near impossiable, the belts also chirp (the belts are new and good and tight). did agr send me a bum pump? and is there any test i can do to verify this? or is it something else that i'm not seeing?
    85 sub / 350 rebuilt / 14bolt ff ,w-detroit/
    dana 60 w-posi/ sm 465 / np 205 / 6" lift / 38.5 swamper sx / 10000 ramsey / custom tailgate
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I think you may just have to get used to revving the engine to turn those big tires while you are sitting still. It takes a lot of force. It is also very hard on the frame and steering linkage, so I would avoid trying to turn the tires when you are not moving.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I can turn my 36x12.5 TSL's w/ my pinky when the truck is stoped. I have all stock stuff that leaks all over the place. I would call up AGR to see what they will do for you.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  4. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    I would have to agree with Dan on this one. Something is not right. I would call AGR and see if they are any help. You could also PM Boss on the main board and get his opinions on it. I know he has delt quite a bit with AGR. Good Luck.
    See Ya,
    Keith
    <font color=green>Born to Drive My K5</font color=green>
    <a target="_blank" href=http://coloradok5.com/gallery/californiak5>CaliforniaK5's Pictures</a>
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yup my stock pump/box will turn my 35s just fine while stoped. Mabie you still have air bubbles in the system?
    Good Luck
    <a target="_blank" href=http://coloradok5.com/gallery/Burt4x4>http://coloradok5.com/gallery/Burt4x4</a>
  6. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    I changed my hoses and I had to bleed it alot to get all the bubbles out. Jack up the front end so the tires are off the ground and turn the wheels lock to lock slowy a couple times, check the fluid, repeat. Do it for a while and try driving it agian.
    Never said I could spell!
    '70 K-20 San Diego, CA
  7. Burt4x4
    6,854
    Ya that is how I did it! I would let it sit (motor off) for quite a while the repeat the process until the bubles are no more...
    Good Luck
  8. JoshA
    JoshA 1/2 ton status
    Apr 9, 2001
    104
    slc,ut
    I agree that something is wrong. your steering should be fairly easy. I put an autozone steering pump on and I can steer with my pinkie finger, sitting still, at idle, on concrete. I have 35" 12.50's with duel stabilizer shocks.
    '72 blazer 9" lift YOKO mudders 35x12.50 350/sm465/3.73 UTAH
  9. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Ditto POFF on bleeding the heck out of the box. I helped a friend install an AGR box and pump and we had his front end up in the air with the motor running, bleeding it for about 12 minutes before we got the thing to work right. We had to stop three or four times to refill the reservoir.
