power steering
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mdm365, Feb 12, 2002.
  1. mdm365
    mdm365 1/2 ton status
    Jul 2, 2001
    536
    mineral wells wv
    now that I got my new motor in I can get the power steering in at this time, its manual--however I found a power steering box from a member but it takes the flare type hoses my question is can I change the valve on the back were the line goes in from o-ring to flare fitting type by using one from the early model pump?
    1977 k5-blazer4"pro comp lift 3.5 in rear dana 44,12 bolt rear, 350 &,205 t-case,465 trans,flotech headers and mufflers
  2. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    Almost definately. There were a couple of very small changes very early on. but more than likley they would just swap out with no problem. While your in there you can boost the pressure by following the tech article on my website.
    www.westtexasoffroad.com
    Sorry don't know how to do the clicky thing
  3. mdm365
    Jul 2, 2001
    536
    mineral wells wv
    thanks for the reply --I looked at your tech page and follow you on this one.Now I need to go to the bone yard and find what I need.I never tried that one so I was not sure. Thanks !! mike m
