Power tailgate owners--PLEASE LOOK
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88K5Jimmy, May 17, 2002.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    I can't roll my window down from the outside anymore. I am pretty sure the part you stick the key in and turn needs to be replaced. Have any of you guys done this and how hard is this? Any tips or hints?
    Ross
  2. dyeager535
    26,980
    You can tear it down and "fix" the contacts, which in my experience, get dirty. If it works from the interior switch, but not the key switch, that is likely the problem. Search for tailgate fix posts, its been covered a few times...heck, search by my username back about 3 months, and you should see a couple threads on tailgates in there, and how to fix/work on them. But you gotta dig through all my other posts first : )
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Its not a big deal to fix it. Just take off the inspection cover and the whole thing is held in by 2 bolts. Take them off and disconnect the connections and thats about it... mine was corroded too bad to be fixed....so I threw on a soft top /forums/images/icons/smile.gif
