power W/L question
Discussion in 'The Garage' started by stoney126, Jan 9, 2007.
  1. stoney126
    stoney126 1/2 ton status
    Jun 2, 2005
    1,458
    napa,CA
    hey all I got some doors from a friend, 4 off a suburban for free, there even the same color :D . There power W/L and my truck is very much standard. So What should I look for on my fuse block? Also any trick to getting the door panels off?
    Thanks for the help
  2. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    No trick to the door panels. Just remember to get all the screws:D
    Let's see if I can remember. 2 in the armrest, one just in front of the arm rest, one in the door latch and 5? Maybe 4? Along the bottom of the panel.
    Un-screw the door lock knob. Hardest part is popping the top loose from the window chanel. Use "A modicum of Force":bow: To be vague about it:haha:
  3. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    so what will the fuse block say if it has a spot for power windows and locks?
  4. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    ok A better question how do i hook everything up? The books I have are all chassis wiring and dont have anything to do with the lock and windows.
    Any help is appreciated
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If you still have access to the Suburban, go back and take out the entire harness for the doors. It is separate from the rest of the harness, so it's not too difficult to remove. You'll get all of the plugs, relays, etc. The nice part is that you then only need to connect two wires into your truck. "Always On" power for the locks and "Switched" power for the windows.
  6. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    but will my fuse block have spots for it?
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    If your model year was available with power windows and locks, then it should have a place to plug in the harness. If not, then you'll have to get creative.
  8. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    Bump to subscribe to the thread for more info. Looking at doing this also from a Suburban to a crew cab.:D
  9. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    Im gonna get a new harness. Gonna find out out wher I need to plug it into on my box or if I even can
