Power washing a 6.2....
Discussion in '1982-Present GM Diesel' started by 84CUCV, Jul 11, 2003.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    I was going to try to clean up the engine bay a bit with motor cleaner and a my bud's power washer. I was going to leave the it running to. Good idea or a bad one? Thanks mike
  2. edeslaur1
    edeslaur1 1/2 ton status
    Jun 23, 2003
    193
    Oregon City, OR, 97045
    Well, no plugs to get wet, so shouldn't matter.
    OTOH, if you get water into bad places do you want it running where you can bend a rod or not (where you prolly won't bend a rod if you start it).
    Personally, I'm judicious with the power washer and careful and leave it running.
  3. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    yea i leave mine running all the time.. /forums/images/graemlins/thumb.gif
  4. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    if you do it when its running i would stay away from the injector pump, i've been told that cold water on a hot pump can cause the pistons in it to lock up.
  5. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    This is true, I would do this with the engine off.
  6. edeslaur1
    Jun 23, 2003
    193
    Stay away from the injector pump no matter what. Water in there is bad mojo. /forums/images/graemlins/smile.gif
  7. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    I would stay away from the GP controller too
  8. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    thanks guys!
