Power washing under the hood
Discussion in '1982-Present GM Diesel' started by TowRig, Sep 12, 2001.
  1. TowRig
    TowRig Registered Member
    Sep 4, 2001
    7
    Wisconsin
    Ok. So the sticker on top of the radiator says don't use water to clean under the hood but I've been powerwashing my (gas) engines for the past 15 years with no repocussions. Any reasons why I can't do the same with my diesel CUCV?? I hate not being able to see the gasket leaks through the dirt buildup.
    Ahh.... torquing on a cup of cofffee with the smell of diesel exhaust on the way to work....humm...way to the deer stand.
  2. 6.2 man
    6.2 man 1/2 ton status
    636
    Curtis , WA
    Thats the best part of a diesel ...water won't stop it un less you get in the air intake . i wash mine all the time . I stay away from the air in take ...wash and nothing to do before starting it !!!
  3. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Don't wash the dirt off....you will open all the leaks that have been plugged by the dirt and grime!!! You will have leaks all over the place!!
    SK-15
    J**P...it's whats for dinner!
    Roads? Where we're going, we don't need any roads!
    If it wasn't for bad luck I would have no luck at all!!
  4. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,038
    1,106
    Dallas
    By washing my engine off, I got water into my eighth cylinder. When it came time to crank, the rod bent as well as gouging into my crank. We pulled the head and pan and replaced the rod and piston. It ran fine afterwards, and lasted until 300,931 miles at which point we chose to replace it. I recommend avoiding heavy washing.
    David Oliver
    '85 'burban
    B&B 6.2L J NA
    T-700
    5.5"lift, 35"BFGs
    *Banks Turbo coming soon*
