Power Window Idea <--- IT WORKS
Discussion in 'The Garage' started by Jason4x4, May 2, 2007.
  1. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    I have been thinking about my slow power windows. It seems it isn't just mine, but everyone's. SO I have been seeing alot of topics about adding relays to headlights to make them brighter by adding full battery voltage. And I already added a relay to my starter for the same reason.
    So, I am thinking about adding some relay's to my power windows, I looked at a diagram today at work and it didn't show any. I have no problem wiring it up, but has anybody tried this yet? If not, I think I will give it a whirl and maybe do a write up on it.
    Let me know what ya'll think. :D
    EDIT, I just got one side done, The drivers, and it is almost twice as fast as the passenger side now. It used to be slower. I used 2 standard bosch relays.
    Terminal 85- power from the window switch.
    Terminal 30- To window motor
    Terminal 87A & 86- to Ground
    Terminal 87- Goes to power, I used the junction block on the firewall, so I get as much voltage as possible.
    I am going to do the other side, it is just too hot right now. It was pretty simple, and they work soo much faster. It's amazing how much voltage drop there is on 25 year old wires and connectors.
    here's a pic of where I put the relays. I took the pic before I ran the power wire to them.
  2. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Interesting.. :thinking: just don't have your fingers in the way on the first test. ;) :D
    I too need to do something with mine soon. They're getting slow.. they've never been great since I've had it, but they're just getting worse every year. I've even gone in a did all the TLC stuff, to little avail.
  3. Redwookie
    Redwookie 1/2 ton status
    Apr 5, 2007
    247
    Charleston, SC by way of the PHX
    Sounds interesting. Sorry no advice here but I'd love to here how it turns out. I'm tired of "helping" my windows up.
  4. FlatBlackBurb
    FlatBlackBurb 1/2 ton status
    Mar 23, 2007
    390
    Santa Cruz, CA
    get a vid in case the window shatters :D
  5. lectric80
    lectric80 3/4 ton status
    Apr 4, 2007
    9,508
    Grantsville, Ut
    I don't know about using full battery amperage as it may do as the above have stated and shatter a window, but if you could put say 50-60 amps to the system it should really speed up the windows. I have the same problem with my Astro windows they are extremely slow, especially when compared to the wife's Lumina. Let us know how it goes and what you did specifically, since I plan on adding power windows to the K5.
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    The window motor will only pull as much power as it can use. If you put a 10,000 amp source to to 2 amp motor it'll still only draw 2 amps.
    The same CAN NOT be said of voltage.
    Voltage is force, amps are flow.
    A friend of mine has done the relay trick on his 4runner. He has a write-up on it out there soemwhere.
  7. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Since the starter has a direct line from the battery what good is a relay there? How much more power can it get?:confused:
  8. mrdrinksalil
    mrdrinksalil 1/2 ton status
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    I wouldn't bother. I tried this allready but hooking the two wires from the motor right to the battery. Only like 2 feet of 10 gauge wire too. I had a friend hold the battery by the door while i held the leads to it. No faster. And yes, it was a good battery. Red Top Optima.
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    just go wheeling again , put rock in door , then you can remove the door :pimp:
  10. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I put in new motors and my windows go fast now.
  11. lurtch-k20-(78-90)
    lurtch-k20-(78-90) Registered Member
    Nov 8, 2006
    55
    Troup, tx
    If you were to take the motor apart, clean the commutator(The copper area that the brushes touch), replace the brushes, bearings or bushings, change the grease (remove all of the old dirt encrusted crap), and regrease the window slides. Then everything will move easier and faster.
  12. Jason4x4
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    It Works
    It works, see post # 1. A while back when I replaced the window seals, I put new rollers on the regulators, and cleaned and lubed everything, they were still slow.
  13. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Try the Furd relay configuration, it works!:D
  14. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Good Engineering, but two relays?
    Edit; I get it, one relay each window.:doah:
  15. Jason4x4
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    one relay for up, one relay for down.
  16. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Then I don't think you need two per, just one upstream from the switch.:confused:
  17. Jason4x4
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    I put them downstream from the switch, so that i'm not losing anything through the old switch.
  18. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Yup, I was wrong, but does the motor run from two or four wires?
  19. Jason4x4
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    motor has 2 wires
  20. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    So the stock switch just flips the current. OK, I'll stop here until I look at diagrams again.:haha:
