Power Window / Interior Door Panel
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dawson444, Feb 27, 2001.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Hey, my drivers side window will go down fine. Then will go up about 4", then stop. I can pull on it, get it almost all the way up, then it will start going on its own again, whats wrong??? I tried to pull the door panel off today. I took out every screw I saw. I got most of the panel loose, but it won't come loose on the top by the window, please help! Thanks!
    Dawson
    Raleigh, NC
    88 K5, 4" lift, 33" BFG muds
  2. Mr Red
    Mr Red 1/2 ton status
    263
    Washington, DC Metro Area
    What year rig??? I'm facing the same thing. My passg. side glass on my '91 does same thing. Figure I'll take off the int. panel - if we get some advice- and what I plan to check is the alignment. I think you have to pull the bottom of the panel out, then push up to remove the door panel; I just don't know if that is right. When I worked in a garage, I remember pulling panels and still being able to raise/lower the window to see how it runs in the track. If you're brave, that's a way to figure it out and is what I'm planning to do.
    <font color=red>David, '86 & '91 K5</font color=red>
    Forever missing Dale Earnhardt, who drove over more Fords than we could ever dream of
  3. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    Mr Red is right you have got to push up on it if you can roll you window down that makes it easy but if not you can still get it off the same way Just pust up on it
    [​IMG]If you want to run cool
    you got to run on Heavy Heavy Fuel
    <A target="_blank" HREF=http://www.trailblazer90.coloradok5.com>http://www.trailblazer90.coloradok5.com</A>
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    The panel is a PITA to get off sometimes. You just have to force it up, it feels like your gonna break it in half. Use about 2 gallons of elbow grease, it'll come off eventually.
    Murphy's Laws on Life :
    "Leftover nuts never match leftover bolts." [​IMG]
  5. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Ok, is it going to be really hard to get back on if it is this hard to get off? Anyone have any ideas on how to fix the window its self? Thanks!
    Dawson
    Raleigh, NC
  6. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    It's not hard at all to get back on, it just kinda snaps back into place. You may wanna put a healthy amount of grease/WD-40(grease will last longer I believe)on the motor gear, regulator gears, and the little slider wheels. See if that helps first. Also check to slide wheel tracks for any obstructions that may be causing it to slow down or stop.
  7. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I'd stay away from the WD-40 for the windows. They've changed the formula and it just doesn't seem to work as well now. I'd use some of the Special Marine Grease made by Lubriplate (Part #20601 for 14 oz can) for greasing the gears, slides and joints. This stuff never dries out, the melting point is 425 degrees and plain works great.
    I'd be looking at the slide attached to the bottom of the window and also the rollers for the problem you're describing.
    Smitty
  8. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    very standard problem with blazers. passenger side usually goes first for some reason, then the driver's side.
    i found that a couple of beers makes the panel removal portion far easier. not enough to damage anything, but buzzed enough to just get the freakin panel the hell off that door!
    there's a few posts on this subject, describing remedies and techniques for cleaning everything out, or removal / installation of motors. do a search, there's diagrams and crap, too.
    my pass side is completely dead, and the driver's side will only go down if i help it. i think that project is creeping to the top of the list.
    <font color=purple>delta9blazer</font color=purple>
