Power window issues
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mreetz, Mar 12, 2007.
  1. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I have an '84 K5 with no power to the window for some reason. It won't work to operate either the drivers side or passengers side window. Power lock works tho.......
    I replaced the switch with no change. Is there a seperate fuse for this?
  2. trikstark5
    trikstark5 1/2 ton status
    Feb 17, 2004
    169
    usa
    Yes, there is a fuse for the power windows. You can always check for voltage at the switch by either using a digital multimeter or a test light. There should be a hot wire (12 vdc) that is constant on the switch.
  3. engrgrad
    engrgrad Registered Member
    Jul 18, 2004
    32
    Michigan
    also verify that the wiring going to the drivers side switch is not loose/broken/corroded as that is the master switch. I had the same issue with my truck where one rear passenger window was not working and found that a wire connecting that motor to the drivers master control was corroded
  4. Mreetz
    Jun 26, 2001
    1,282
    I think it is a power wire issue cause I can get the passenger side window to work from that side.
  5. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Check all your connections, Positive and Negative (ground). At the door hinge does your wiring go through a bellowed hose or is it a icky-poo ( :D ) exposed set of connections that only make contact when the door is closed?
  6. Mreetz
    Jun 26, 2001
    1,282
    It goes through a bellowed hose.
