power window motor replacement
Discussion in 'The Garage' started by 84CUCV, Sep 10, 2006.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    just need to know what is a good way to go about it. does the door need to come apart? really have no clue how to do this. i thought this would take like 1/2 a hour to do and call it a day. looks like a real pain tho. any help would be great thx
  2. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I have done it a couple times. I always cut a hole in the door by the motor to access the bolts. Most speaker holes will allow you to see it.
    Real easy with proper access holes.
    BTW - Liz Vicious is HOT! ;)
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    will the panel cover the hole? not sure where to make one. thx
  4. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    oohhh yea she is real hot.
  5. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    It will cover the hole, for sure, if you have lower carpet panels. I reall can't remember where to make the hole. I just remember looking through speaker hols and seeing that if I cut a hole over here, I can get to those bolts real easy :)
    Look down the door and see where the motor is and see where you need to drill some holes.
    If not, I think you need to take the regulator loose, scissor it down (might have to take out the window) and get the motor up to the access panel area. Its actually pretty easy to gut the door. Not that hard at all. Just pe prepared to cut your wrists up and be totally pissed off by the time you are done lol
    Cutting an access hole is the way to go. Its fast and simple.
  6. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
  7. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    I found the hardest part was in reassembling them so that the window and gear are matched. I'd suggest using tape to mark where the window is when you remove it (easier to do about half way down) and making a mark on the gear teeth as well.
  8. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
  9. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    thx guys
