Power Window Porblems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Mar 6, 2003.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    My power windows dont work anymore I thought I had blown a fuse so I replaced it. And they still wont work. When I press the button for them to roll up or down the light under the dash turns on. Any suggestions on how to fix?
    oh yeha when the windows did roll up and down he light under the dashe never came on.
  2. BlaznRebel
    BlaznRebel 1/2 ton status
    Sep 1, 2002
    115
    Louisiana,Baton Rouge
    sound like something has shorted under the dash. Power is being sent to the light instead of the windows. Will either window roll up like the driver? All you can do is start running down your wires till you find the culprit.
  3. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    they both wont work at all for me.
  4. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    had similar problem on mine all i can tell you is get out a wireing diagram and a test light and start checking
  5. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    There should be no light anywhere on the window wires. I would assume someone monkied around with the wiring durring a stereo install or something. I would start to seperate the wires and look for splices that dont belong.
    Also, if the drivers door switch has problems then the pass door should not work since the pass door pulls it negative from the drivers door switch.
