Power window problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scottnj, Apr 25, 2002.
  1. scottnj
    scottnj 1/2 ton status
    Aug 4, 2001
    112
    Central Florida
    Hello. I have a 1991 Blazer. The passenger side power window has always been slow and sometimes stops.
    I went ahead and bought a new motor. No difference at all.
    The drivers side is slow also but never stops.
    I am thinking maybe ther eis a voltage problem going to them.
    My voltage meter on the dash always shows a little below 13 and sometimes even less but at the battery it is always around 13.5
    Any help would be appreciated. Thank you.
    Scottnj@cfl.rr.com
  2. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    Do a seach, There has been alot of discussion on this one..
  3. K05Aggie
    K05Aggie 1/2 ton status
    Feb 22, 2002
    136
    Dallas, Texas
    Try lubing up all the rails in there with white lithium grease. It helped my windows.
  4. scottnj
    Aug 4, 2001
    112
    Central Florida
    I will go try that now. Thanks
  5. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    check the ground connections right on the top part of the grill....i had the same problem and it ended up eating my alternator
  6. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,259
    72
    Humboldt/Pacifica, CA
    My passenger window does the same thing, it will stop half way up. For some reason it seems to get crocked and I can see that the back side of the window always wants to go up before the front side of it. Just haven't had the time to figure out why it does it, but I think that something inside must be worn a little. Maybe you have the same sort of a problem ... and can tell me the answer /forums/images/icons/smile.gif
