Power Window Problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 8BaLL, Jun 13, 2002.
  1. 8BaLL
    8BaLL Registered Member
    Jun 13, 2002
    64
    Northwest Missouri
    My power windows on my 85 Blazer run like turtles. what can i do to speed these things up? do the motors need to be replaced or what?
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Most likely you need to remove the motor and regulator from the door and clean off all the old grease and grime then relube it with new grease and it should then work fine. The reason that they start to slow down is because dust and dirt that gets inside that door area starts to attach itself to the grease and it becomes sticky and wants to slow the motor speed. I will be fixing my passenger door soon myself.
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    While your in there, go ahead and check to see if the motor is getting a full 12 volts.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My right one jams up in the window seals. Time to replace those.
