Power window switch tip
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by heavy4x4, Oct 13, 2002.
  1. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    As some of you may know, I'm in college. Well, the truck's been sitting at home for over a month and I went home this last weekend and drove it. Things were allright although it was definitely evident that it hadn't been run in over a month. Anyway, on to the subject of my post. When I got in and went to unlock the doors, I pushed the switch up, and nothing happened. Then I pushed it up really hard and the doors unlocked. The passenger side had been doing this for over a year and I was convinced that the switches were just getting old. So, knowing that if the switches were going to be junk, I didn't care if I wrecked them. So, out came the WD-40. I put that little red tube thing (the one you always lose) on and sprayed right inside of the switch. Let me tell you, it was awesome. The WD-40 must have eaten any corrosion that was on the electrodes because now the switches work like brand new. You barely have to push them at all and the locks go up and down. Fastest and easiest fix to crappy power window controls ever...try it!
  2. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    Yea they get full of dirt and moisture and start to corode(sp)I usually pull them out and clean all the contacts with emery cloth and put some electriccal lube on them
  3. mattyblazer
    mattyblazer 1/2 ton status
    Sep 22, 2002
    202
    Long Island, NY
    If you can get koprshield from an electrical supplier, it works great, never comes off increases conductivity, and will not allow oxidation.
    Matt
  4. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    Thanks for the Tip I'm going to try it now /forums/images/graemlins/thumb.gif
