Power windows '91 Full-size
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cowboy, Jun 7, 2002.
  1. Cowboy
    Cowboy Registered Member
    Apr 4, 2000
    6
    South Carolina
    Power windows \'91 Full-size
    Having a problem with driver's window. When putting up or down will just stop. Will resume if I wait a minute or so about a half inch at a time. Have replaced the switch. Didn't help. Anyone encountered this?
  2. wirex
    wirex 1/2 ton status
    Oct 9, 2000
    102
    FLEMINGTON NJ
    Re: Power windows \'91 Full-size
    did you put a meter on the switch when the window
    stops that will tell you if you have a open or just a bad motor
  3. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I just took apart the passenger door, removed the whole regulator and cleaned it up really good. Regreased the gear and now it works great. Hope this helps.
  4. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    Mine did pretty much the same thing when the motor was shot. If it moves REAL slow when it does roll up/down, its pretty safe to assume that motor is worn out.
  5. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Mine was just nasty dirty...once I cleaned everything up it runs just fine.
  6. Blazin Ed
    Blazin Ed Registered Member
    Mar 29, 2002
    92
    Seattle
    My '88 passenger side window takes about 2 min to roll up or down... Is this the motor going bad???
