Power windows are sloooooooooooooowwwwwwwwwww!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Erich_in_AZ, May 22, 2003.
  1. Erich_in_AZ
    Erich_in_AZ 1/2 ton status
    Mar 23, 2002
    237
    Tucson (it\'s a Dry heat), AZ
    OK, we all know the power windows are not exactly fast in the earlier Chevies, but this is nuts! My fronts take about 15 seconds each to roll up (one at a time of course). Both front windows have new motors, but they are still horribly slow. Anyone make a faster motor for these? Any tips or tricks? It's an '83 burb.
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Make sure that the motors are getting the full 12 volts, if not they'll obviously run slow. It also helps if you grease up the regulator and the felt tracks. And check to make sure that the felt is in good condition, because sometimes it splits, then the window tries to push up inside the felt and not between(if that makes any sense /forums/images/graemlins/tongue.gif). Good Luck...
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    grease all moving parts inside the door and get some graphite powder for the felt tracks /forums/images/graemlins/thumb.gif
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    run 24V to them they will go really fast /forums/images/graemlins/rotfl.gif
    BTW dont its a joke /forums/images/graemlins/thumb.gif
  5. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    My passenger side was slow for a long time even after lubing up the tracks and replacing the felt. What I did was clean up the contacts on the switch. Just remove the switch and pop the connector off the back. Then I used a Dremel with a wire wheel and clean up all the contacts. I also disassembled the switch itself and cleaned up the inside. Everything was coated with dielectric grease to help prevent corrosion and improve contact. It took about 30 mins and it now operates much faster. Much cheaper than the $25 for the switch assembly from the parts store.
  6. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    get yerself some silicone spray for the window runs, and the regulator, spray them down, pull the wire off the motor, check for full 12 volts, if you have it, grease the connector with dielectric grease and reinstall, retry...
  7. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I have found the rollers to be the weak link in the system. Every GM power window door I have taken apart has had at least one out of three rollers seized. If these do not turn they will slide and that slows it down quite a bit. They are hard to free up once they have been seized and often start to break apart but thats what you get for using plastic bearings /forums/images/graemlins/smile.gif
    Good news is they only cost $5 for a new roller and rivet. Bad news, you have to take out the regulator to replace them...
  8. Erich_in_AZ
    Mar 23, 2002
    237
    Gonna try some of these things this weekend. Thanks for the tips!
  9. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    I have heard that window motors from a Pontiac Grand Am will work on our regulators and they are supposed to be much faster.
  10. scottnj
    scottnj 1/2 ton status
    Aug 4, 2001
    112
    Central Florida
    Clean out the tracks and rollers with a de-greaser. Then re-grease everything. Dont use white lithium grease. It seems to get hard and slows it down quite a bit. Just did mine a couple months ago and they are faster then they ever had been.
    Thanks to everyone here and the posts I read.
    /forums/images/graemlins/k5.gif [​IMG]
