Power Windows... Help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rem7600, Apr 21, 2000.
  1. rem7600
    rem7600 1/2 ton status
    Apr 16, 2000
    125
    Coeur d\'Alene, Idaho
    Actually, they're convenient, when they
    work! :-)
    My drivers side finally gave up when it was
    halfway down. The motor is still fine but
    something has come loose... A gear? I'm
    tearing into it tonight with the aide of a
    Haynes manual. Any suggestions? How do I
    emergency release the window so that it's
    out of the way (ie: manually pull it up?)
  2. Todd78/87
    Todd78/87 1/2 ton status
    Feb 18, 2000
    436
    Haines, Ak
    Mine did the exact same thing. When you pull it apart, you will find a few of those white rollers in the bottom of the door, I have been manually pushing it up and down for a couple months now. LMC wants 149.00 for the regulator,, I think Year One has them for 125.00
    Todd 78/87[​IMG]
    Alaska Bound
  3. rem7600
    Apr 16, 2000
    125
    Hey Todd,
    You're no longer my buddy! :-)
    I was hoping for better news than that!
    TR
  4. Todd78/87
    Feb 18, 2000
    436
    Haines, Ak
    LOL!!!![​IMG] Why do you think mine is still broke?!?!?! The window stays anywhere I put it, but I might have to fix it soon so I can sell it when I get my 78 done.
    Todd 78/87[​IMG]
    Alaska Bound
  5. Todd78/87
    Feb 18, 2000
    436
    Haines, Ak
    BTW rem7600,, what caliber are you?
    Todd 78/87[​IMG]
    Alaska Bound
  6. rem7600
    Apr 16, 2000
    125
    If you're talking rifle... That would be '06
    if you're talking type of person... High
    If you're talking K5... '89 350
    NOW, here's the scoop. I dug everything apart and the
    large gear which drives the scissors is actually
    slipping on the motor gear or vice versa like one of them
    is stripped but ALMOST grabbing. When you talk of the
    regulator, what exactly does that piece/part look like.
    I've got the window UP anyway... But without AC (need
    compressor for rebuilt system) It AIN'T gonna stay this
    way. I've gotta fix SUMPIN' and soon, summers on it's
    way!
    Hoping for an answer soon!
    REM7600
  7. Todd78/87
    Feb 18, 2000
    436
    Haines, Ak
    Hey I just found them in Cheyenne PickUp Parts catalog for $89.95 ph 405-872-3399 Ooops,, looks like they only go up to 87,, It's the sissor looking thing connected to kind of a square box.
    Todd 78/87[​IMG]
    Alaska Bound
  8. rem7600
    Apr 16, 2000
    125
    Does it include the gear though? The BIG flat one...
    Thanx for the quick answer. As you can tell I'm hoping not to have to replace everything...
  9. Todd78/87
    Feb 18, 2000
    436
    Haines, Ak
    Yeah,, the one connected to the square metal piece,, the half moon looking one, Yep sure does.
    But even LMC doesn't show one for anything above an 87,, yours must be different.
    Todd 78/87[​IMG]
    Alaska Bound
  10. rem7600
    Apr 16, 2000
    125
    Who's LMC?
    I think we're talking the same thing here... I didn't have any white spacers or washers down in the door though. I'll call my dealer tomorrow. The wife's gonna love this....
    Thanks for the info... Over and out!
  11. Todd78/87
    Feb 18, 2000
    436
    Haines, Ak
    Here's a pic,, not a great one, but........
    see attached
    Todd 78/87[​IMG]
    Alaska Bound
  12. Todd78/87
    Feb 18, 2000
    436
    Haines, Ak
    LMC is a catalog order place,,, http://www.lmc.com you can get a free catalog from there.
    Sure Dude,, Glad I could help
    Todd 78/87[​IMG]
    Alaska Bound
  13. rem7600
    Apr 16, 2000
    125
    I think the picture shows it upside down as to the way its positioned on my rig...
    Where r u from and how did you post the attachment? Me, Coeur d'Alene Idaho
  14. Todd78/87
    Feb 18, 2000
    436
    Haines, Ak
    Dude,,, I LOVE Coeur d'Alene!!!!!!!!!!!!!!!!!!!!!! I went to HS in Thompson Falls, MT,,, skiied Schweitzer All the Time.
    Skiing is the only thing Sandpoint has over C d'A.
    I'm in KC Missouri right now,, heading back to Alaska in a couple months with a stop off at my Mom's in T Falls.
    ( 1/2 way point) My Dad and I are going to build a rear bumper with swing away tire carrier and jerry can holders when I get there.
    I took a digital pic and then after you click continue with the check mark in the box that says " I want to preview my post and/or attach a file." Then you put the file name in the box and hit continue.
    Todd 78/87[​IMG]
    Alaska Bound
  15. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    I might be to late but here is a drawing for all others that want to learn what the inside's look like.
    Copy is from the Haynes-manual.
    [​IMG]<font color=blue>Espen88k5</font color=blue>
  16. Todd78/87
    Feb 18, 2000
    436
    Haines, Ak
    Thanks Espen,, what year is that from? All the catalogs I have only go up to 87,, are 88-91's different?
    Todd 78/87[​IMG]
    Alaska Bound
  17. MICHIGAN BLAZER
    MICHIGAN BLAZER 1/2 ton status
    296
    Middleville Michigan
    No 89-91 are the same as any other years....still a pain in the @ss. I replaced my drivers side motor last fall. The difference in the motors was that the old one had a part(can't remember what) rivited to it...I had to drill it out of the old motor and find a tiny screw to put that part back on the new motor. The problem i keep running into is that little screw over time becomes loose and allows the gears to slip.....thus the window doesn't want to go up or down...anyway that's my window horror story...good luck.
    <font color=red>MICHIGAN BLAZER
    <font color=green>89 Fullsize Blazer
    87 Cherokee
    65 IH Scout
  18. rem7600
    Apr 16, 2000
    125
    Thanx for the drawing... I had obviously
    overlooked it in the book. It's out in the truck
    now but I'm sure the pic is there. The attached shows
    where the grind is coming from on mine. Mich Blazer it
    "sounds" like your problem, pun intended! Which piece
    is it that I will need, motor or regulator? I'm guessing
    I'll have to take the stupid thing OUT to find out???
  19. Espen88k5
    Feb 19, 2000
    981
    Norway
    It could just be time for a quick clean and regrease job. You have to take it out thoug. Not a biggy, just take your time and get some help holding the window upp while you jiggle the scissors and motor out.
    It will start to grind and slipp when the scissors get junked upp enough. All rainwater and road-dust that goes through these doors and old grease combined with additonal easyfix spraying does so it gets pretty sticky after a while.
    Mine worked like they where new after I did mine.
    Try if you havent allready.
  20. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    I was just thinking, if you are saying that your gear is stripped, why not use a mig welder and "build up" the gears. After the welding is done (just small "bumps" with the trigger) use a grinder and shape the teeth.
    It may work.
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
