Power windows suck
Discussion in 'The Garage' started by laketex, Jun 13, 2003.
  1. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    How hard is it to convert to manuals? I hate my power windows!!! /forums/images/graemlins/eek.gif
  2. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    Amen, brother. Power windows suck!
    Should be able to install manual regulators and have manual windows /forums/images/graemlins/thumb.gif. You will probably have to get new/different door panels that have holes for the splined regulator shaft to poke through. Those and a couple window crank handles then, in my opinion, you just improved the hell out of your truck /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Just see if someone with manual doors wants to trade /forums/images/graemlins/thumb.gif
  4. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Nah, just cut holes in the existing panels...
  5. laketex
    6,220
    North Texas
    Thanks moses. And I'd have to agree. AFter I shorted my wires, i've had enough. Before they wouldn't hardly roll down for the mud that is gunked in there, but not not at all. I'm done.
    89, have you done this to your truck? I wouldn't mind cutting holes in the existing panels if i was sure it wouldn't be too ghetto. Any advice or parts i gotta switch?
  6. laketex
    6,220
    North Texas
    yeah definately an option, except i'd lose the killer blue paintjob that way. Of course, I seem to be loosing it as is, one dent at a time!!!
  7. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    You might want to PM Bigmeats, I think thats his name. He bought my old doors for that same purpose. So if he's done it he might be able to tell you how hard it was. And I'll keep my eye's open for a set if ya want. /forums/images/graemlins/wink.gif
  8. laketex
    6,220
    North Texas
    Yeah I"ll do that, thanks. If you run across something cheap, then let me know. I had a good set but gave them away. Wish I hadn't now...
  9. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I did the swap on my '84. It's very straight forward. Just pull all the power stuff and bolt in the manual regulator. You don't even need to cut a hole in the door panel either since the crank shaft sticks right through the hole where the window switch used to be. /forums/images/graemlins/grin.gif I think the hardest part was wrestling with the vent window out and manhandling the glass back in...
  10. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    u wouldnt have pics showing how u did ur swap would ya? i got a couple of manual window regs and Id LOVE to get rid of my power window crap...
    j
  11. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Nope, no pics, but heres what ya gotta do:
    (bear with me, I'm trying to remember how it all goes together but you'll understand better once ya get in there)
    1. remove door panel, making sure the window is rolled down - remove all screws, push up on the panel to remove it, it will be hard. Unplug the switch harness, leaving the switches in the panel, you can deal with these bad boys later.
    2. with the window down, remove the vent window assembly - there are three screw on top of the door and one in the middle of the door. I can't remember but you may have to remove a bolt that can only be accessed from under the side mirror cover. Pulling this dude out will be tricky.
    3. Once you get that crap out, loosen the other window guide and manuver the window out of the regulator track and remove the window.
    4. Unplug the motor and unbolt the regulator and slide both out, I think you can leave the motor bolted to the regulator but I can't remember,
    5. Now bolt the manual reg in place, it bolts to the top 4 holes whereas the power reg uses the bottom 4 holes.
    6. "Installation reverse of removal" - Haynes Manual
  12. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I got 2doors(left and right) with manual windows I can pull every thing out them for you
  13. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    power windows, locks, they all suck. after time they break. the only thing that needs power is the engine. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
