Power windows????
Discussion in 'The Garage' started by 85blazerk5, Feb 3, 2005.
  1. 85blazerk5
    85blazerk5 Registered Member
    May 30, 2004
    75
    WV
    Has anyone installed the power window kit from LMC? My power ones are screwed royally and I have replaced both motors, wondering if I should go for a total swapout. Any ideas would be appreciated.
  2. 85blazerk5
    May 30, 2004
    75
    WV
    no one? Just wondering what all entails.
  3. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    I saw that in the catalog. Part#36-0696?
    Looks like junk to me.
    Mine sucked hard at one time. Took them out and cleaned everything. When I reinstalled then I fitted the regulators to the door, I didn't just bolt them in. A few bends on the tabs to make it fit right. I think redrilled some holes too. With new motors and clean/new guides the stock windows should work great. Slow, but dependable.
    Another thing is running new wires. Old wires have more resistance and deliver less power. V=I*R. I ran a new power wire and used the old one to switch a relay to deliver the power from the new wire.
    You can do it, takes some time though. If that is the kit you are talking about I bet you would mess with it longer than it would take you to clean up the stock stuff.
    I always wondered about swapping in a different motor that turns faster. Ford windows go real fast.
  4. 85blazerk5
    May 30, 2004
    75
    WV
    Thanks, I am no good with wiring, I wouldn't even know where to start with the old stuff, that is why I was thinking about a whole new kit...figured the instructions would help me out alot.
  5. sickquad
    Jul 23, 2003
    785
    Ma
    Well, you have to learn at some point. It's real easy, just get a wiring diagram.
    -Chris
  6. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    Someone has been studying OHM's law. :grin:
