power windows
Discussion in 'The Garage' started by sf_wood, Jun 25, 2005.
  1. sf_wood
    sf_wood Registered Member
    Apr 4, 2005
    70
    san francisco ,ca
    I have a 1977 k10 without power windows, i got some clean doors off an 85 k10 w/power windows. I need too know how i can wire these in so they work right.I'm already going to buy a new wiring harness, know of any good one's. Thanks guys.
  2. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    Wiring harness
    Painless wiring has a harness with provisons for power windows, electric fans, and an electric fuel pump. I imagine all you'd have to do is hook it up to 12volts, and run wiring so you can operate the passenger side window from the drivers side. There's no modules or PCM's to fuss with.
  3. frankin5
    frankin5 Super Mall Crawler Premium Member
    Oct 15, 2002
    882
    114
    chico,calif
    if you have access to the "85 truck, get the cross over harness from it. if you are lucky the new doors will have power door locks and you will need that harness to make them work. the stock harness fro windows and door locks have a relay setup under the dash.
  4. sf_wood
    Apr 4, 2005
    70
    san francisco ,ca
    I don't have access to the 85 truck . If i buy a complete harness from painless will it come with everything i need.
  5. frankin5
    Oct 15, 2002
    882
    114
    chico,calif
    if you have access to a pic and pull. any power window door lock harness from blazer,truck or sub will work. 80 model to 87 on truck, upto 91 on blazer and sub.
  6. buffblazer
    buffblazer 1/2 ton status
    Jan 5, 2005
    2,395
    Hudson Colorado
    hey why you are helping him can you help me on the same question i have an 86 k5 with no power but i have access to a 87 sub now how hard is it to get all the junk out of the doors and back into the new ones? i would just swich the doors but mine are brand new and the sub is all dinged up
  7. uglyangelracing
    uglyangelracing 1/2 ton status
    Jun 6, 2005
    271
    Rhode Island
    ok on the 85 86 blazers there is a seperate wiring harness for power windows. If you already have the 2 harness's for the L/R doors then all you need is the one under the dash. It simpley connects to each door harness then one wire to ignition power and the other to ground. I can send you pics if you need them. You simpley connect it to the AUX plug on your fuse block and a ground clip. All of this you can get at any local junk yard for $20- $40 bucks
    Ok now with the suburban same deal except one change. You need a different harness and switch for the drivers door. The suburbans come with a switch and harness for 4 windows.
    If anymore questions or you need pics email me at uglyangl@lycos.com
  8. LongIslander26
    Jun 25, 2005
    256
    Painless wiring
    It should come with everything you need, but you'd have to check with them to see if the door-to-door harness is part of it. They say "Complete" harness, but I'd ask them to be sure.
  9. buffblazer
    Jan 5, 2005
    2,395
    Hudson Colorado
    how hard is it to remove the guts from the sub's doors and how hard is it to put them back into the blazer?
  10. uglyangelracing
    Jun 6, 2005
    271
    Rhode Island
    doesnt take that long maybe an hour. But dont forget you need to remove the door to drill the holes for the wiring and pop rivet the boot in. Thats the pain in the a$$
  11. Grieby54
    Grieby54 1/2 ton status
    Jun 18, 2005
    782
    Houston, TX
    I'd go with Painless wiring... just plain easy stuf...and I hate to wire
