Power windows
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazinHi, Jun 10, 2000.
  1. BlazinHi
    BlazinHi Registered Member
    Feb 27, 2000
    5
    San Antonio, TX
    Hey guys I have a question here. I have done this project on two trucks one P/U and on my Blazer. I took the power doors out of a new model and mounted them on mine. Now I can always get the windows to work, but I can't get the power locks to work. I have tried wiring them every which way but no luck. WEll if any body has an Idea please let me know.
  2. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Can't help with a wiring diagram , my book is for 80-87. But the power goes to the switch, then the three wires go to the solenoid, one ground, one up and one down., if you remove the solenoid , you can test it off the battery to make sure where your wires go. Any more just let me know...
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  3. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Hey Blazinhi, Eagle and I got crossways on a similar subject earlier, so first off I don't wanna make anybody mad.[​IMG] The doorlock solenoids I get at the salvage yard (stock GM's) just have two wires. You just reverse the polarity to make it lock (down) or unlock (up). What I mean is +12v goes to one wire, say grey, and ground goes to the other, say brown, this will make the solenoid go one way. Change the wires +12v to brown and ground to grey and the lock will go the other way. This takes a DPDT (double pole, double throw) center off, momentary switch. Maybe Eagle can make a drawing for it or if not I'll try. I have been to the "Eagle School of Drawing Attachments" I just haven't tried it yet!!
    Hope this helps!
    Michael [​IMG] http://jmartin.net/parker/goose.htm
  4. Michael
    1,576
    Sherman, Texas
    OK, Forrest. I will attempt to attach a drawing for the door locks.......here goes!
    Well, that bit big ones! Sorry!
    I may have to enroll again! I'll try again on the next post....after that it's up to Eagle!!
  5. Michael
    1,576
    Sherman, Texas
  6. BlazinHi
    Feb 27, 2000
    5
    San Antonio, TX
    Thanks for the dia I will try it out tommorow.
    Blazinhi...Blazinlow...Blaze a trail..Lets GO..
